Negative Battery Post
Just want to confirm this is the negative battery post?
Appreciate all the info and help.
Piening2150
Toledo
2017 Charger Daytona 392
Ground stud, yes.
Great...thought so.
Did someone call for a stud??????
:ROFLMAO::ROFLMAO:
Why are your posts always so negative ?? [thankyou]
The cables are a dead give away. I am self adeemed the bat rey king. As much problems I have had with em,,, I have learned. Stays on a dick trickle charger. Remember Dick in stock car racing?? What a name. Having the battery in the trunk is not a good idea.
His parents must have had a hell of a sense of humor.
Speaking of Dick trickle charger...debating on hooking mine up while it sits for 2 weeks.
While I don't think it will hurt to hook it up, mine goes 2 weeks all the time without issue, at 4 weeks it occasionally gets a bit slow to start.
If I knowingly was going to go beyond that, I would hook it up.
.02
.02
Thanks Bull. Have done 2 weeks before with no issues...but battery is 3 years old and some have replaced battery at this time. Didn't want to come back to a dead battery. Probably overthinking things as usual.
If I know I'm "putting it away", I make sure that I don't start it and then immediately turn it off (not giving it a chance to fully recharge from the start).
So in other words, I start it, it runs for a minimum of ~15min, I move it to its nest, then shut it down.
No quick starts, short moves, and then shutting it down.
My 3rd battery in 3 years,,, dealership told me to start the car every day to keep the battery in check. With my mild sence of humor, I told them that it will be back with another dead battery cause I ain't going to start the car every day. Well, the Florida sun takes it out of the battery. Well hell, jurk off, it stays in a garage that is conditioned with an insulated garage door with 4 inches of insulation. Beat that said Michael. I have a Nissan that sits in the drive and may not get started for a month with no problem. As fer Dicks Trickle. I am sure he is dead by now. Poor bastard did it to himself. Had a good NASCAR life style.
You got it...always give it a good drive before leaving it for 2+ weeks (which isn't very often). Battery seems good...so will just let it sit and charge battery before I start it up again. Thanks everyone.
That's what I do to my gals.
That hose sure looks like it could go on that fitting on the LTR tank a bit further?
.02
Yeah I go 2 weeks without a start pretty regular. That's about my max though before I will take it out and run it.
Well now that @Hellcatcfp has waved the flag his car will be available to steal or drive 😁. Thanks for the heads up😬
My car sits like that and definitely drains it, killed my 1st battery @ 2 years ! I connected a pigtail w/quick connector to the battery itself and hook it up to the trickle charger if it's going to sit for more than a week. Easier to open/close the trunk than the hood & you can close the trunk lid on the wire when charging. Probably overkill, but I've had no battery issues since.
