- CA
- 2018 Dodge Charger SRT Hellcat
Figured I would seek advice here. Purchased our 2014 Ford F550 6.7 powerstoke diesel motorhome in 2014. Truck has a manufacturer's warranty of 5 years/60,000 miles.
Two years in noticed a slight oil leak which turned out to be an upper oil pan leak which was repaired under warranty. Two more years go by and another upper oil pan leak shows up again...repaired under warranty in August 2019.
Yesterday, changing oil and fuel filters I noticed moist oil again in the very same spot as the prior two oil leaks...so I say fu@#k.
Now out of warranty and past 1 year/12,000 (which I believe is repair warranty). Do I have any standing as this repair has failed again? Out of warranty for sure, but this oil pan has not been right since day 1. Not a daily driver and only has 35,000 miles.
Planning on calling the shop (don't really like them by the way) and speaking with the shop manager to see what can be done as I'm frustrated by this.
I might be out of luck, but upper oil pan was never installed correctly from the factory nor repaired correctly twice since.
Any ideas or am I missing something?
Appreciate any advice.
- 1
