Perf Dev Diff. Brace
So, finally installed my brace (older version) and have a question:
I could not install the rubber spacer (absolutely no room / spacing for it).
Is it ok to have the brace installed metal to metal?
Would using the Quick Jack (meaning no weight on rear end during install) cause there to be an issue with not being able to use the spacer?
Thread Starter #2
Anyone?
I've installed two of them and on mine I was able to use the rubber spacer. While it likely won't hurt much of anything, you do have metal to metal contact at that point, and there will likely be some movement (rubbing) so over time the finish will get marred. Drive in bad conditions and it'll rust on the cradle. That's gonna take a looooong time to ever be a problem I think unless you drive it on salted roads and never wash it though.
I'm trying to remember what I did when I installed mine. The original was on Race Ramps so suspension loaded. The upgraded one I did on a lift and I had to get some help with pry bars to line things up, so you're theory may be right with the lift.
My .02 cents.
guess ya gotta ask that question mon../fri..9 to 5...
I'm on more often during those times actually LOL. Don't tell my boss.
My .02 cents.
Thanks. Originally, I had watched your video on it (a year or so ago). I really wanted the spacer on it, but would not fit.
Might try race ramps and see if it allows for the spacer.
oilburner
coboconk
are you raising the car an supporting via the diff?? if so I would say that`s why that slim rubber piece won`t slide in place.
Used a quick jack
Make sure it's not the order of operations as well.
oilburner
coboconk
Used a quick jack
is the weight of the car on the jack under the diff?? that would cause the narrow gap not allowing room for insulator.
oilburner
coboconk
maybe I`m confused :unsure:,what is a quick jack. I`m spoiled only used car lifts an floor jacks my whole life.
oilburner
coboconk
had to google quick jack, now I know :) seen them before never used one before. looks like a sore back jack to me.
Octanewide
House of power
Can you post pics? I'm not sure how it would fit without it
I'm not sure I like the idea of that bracket without a compliant aspect to it...
:unsure:
Used a Quick Jack.
No weight on differential.
@Mo-par! might be the best source to ask.
He's not on here a lot, check over "there".
It might be due to the Quick Jack use.
Absolutely no room for the spacer.
Will try backing onto ramps, loosening the 2 frame bolts and see if I get any spacing.
There was no way to place the 2 main bolts back in the differential with the spacer in place.
@Speedy! Has a video on the install.
Watched it awhile ago.
Thought it was pretty straightforward, until yesterday when the spacer wouldn't fit.
