Unknown Noise
ELLENBORO
NC
2016 HellCat
2016 auto. Going for a cruise - everythings normal. After 30-40 mi. I get this noise that you first notice as you come to a stop. It sounds like it could be something in the tire, but it's not. You slow down, it slows down, you speed up it speeds up. But you can only hear it it very slow speed. The longer you drive it, you can hear it at normal speed. No vibration or anything else strange, just noise. Any suggestions?
Piening2150
Toledo
2017 Charger Daytona 392
STAR Case number S1522000002
Release Date: 12/15/2015
Symptom/Vehicle Issue:
Click Sound Heard From Front Of Vehicle During Turning At Low Speeds
Diagnosis:
An audible “click” sound may be heard in the front of the vehicle during low speed turning in forward or reverse directions. This clicking noise may be caused by a dirty wheel surface mounting area.
Note: This applies to 2 piece and traditional 1 piece rotors.
Repair Procedure:
1. Clean the wheel matting surfaces on the back of the wheel and front face of the rotor hat
using a finger bristle disc such as a yellow 3M Scotch-BriteTM Roloc 07525 with holder 05539, and/or Scotch-BriteTM Brake Hub Cleaning Disc Kit 07547 or equivalents .
https://www.hellcatforum.org/threads/two-piece-rotors-clicking.243/#post-6018
What kind of noise..scrape..bang..grind..click..howl..what kinda noise you talkin about,,:unsure:
Sounds like the noise of a small child in the back seat. The noise gets louder the faster you are going and turns into a soft grumble as you slow down. Similar in loudness to the female sitting next to you but completely different look on the faces:unsure:
M
ELLENBORO
NC
2016 HellCat
Best I can describe is something between a clicking and rubbing. It's low freq. Again, it don't do it for about the first 30 mi. Then becomes noticeable as your stopping. Can't feel it, but can hear it (slight noise) in the car. Wife says she can't hear it outside as I roll by. The more you drive it gets to where you can hear it as your traveling 60 mph. It's definitely rotary, and worsens as things heat up. Crazy question - Can tires be expanding as they heat up and causing a rub? I've raised the front end, spun the tires, nothing loose, no noise, slight brake drag (as normal)
Post #2 may be what you are hearing
Piening2150
Toledo
I don't know after post #5. Shouldn't be able to hear it at 60 MPH. However, it's super easy to pop the wheels off and clean those surfaces to be sure. Make sure to properly torque the lug nuts 111 ft/lbs too.
OP- unless you're running really wide aftermarket wheels/tires, normal thermal expansion won't cause a rub.
Video of the sound?
Perhaps both from inside the car, and from a helper as you drive by?
Does your Hellcat have any after market Mods?
Linda :)
M
ELLENBORO
NC
2016 HellCat
Stock tires and wheels. I'm not sayin' it ain't brakes, or the mating surfaces, but I don't believe it is. Noise speeds up with the car (after 25-30 miles) and sounds like something rubbing on rotation. I was wondering about something going on in the drivetrain. Is something happening when fluid reaches a certain temp (I surely hope not).
M
ELLENBORO
NC
2016 HellCat
Take a look underneath and look all the way along the driveshaft and make sure there are no score marks going around in a circle.
oilburner
coboconk
do yourself a favor an check wheels for torque, so it can be ruled out.
agreed...then check every visible moving part,for some kind of wear marks..keep a log of everything you rule out..,
M
ELLENBORO
NC
2016 HellCat
I will give it a good inspection. Thanks for your time and input. I will post findings
