- Orlando
- FL
- 2015 Dodge Challenger Hellcat
Welp, figured I’d start a build thread so my stuff is all in one place and not scattered in multiple threads.
2015 Challenger Hellcat A8
Cheap diff brace
BMR cradle lockout
3.09
E85, 1300x2 injectors, dual pumps
Shorter rear sway bar end links
Longer rear wheel studs
Custom hub centric spacers
17x10” F14 beadlocks (MT 315/50r17)
18x5” F14 skinnies (MT 28x6 et street)
2.69 upper pulley only
JLT intake
IC Chiller
Kirkey seat
Custom rear seat delete
9.8 @ 142 leaving off idle like clockwork
Goal is 9.3 or better.
Will be focusing on heat removal, supercharger efficiency, and eventually more suspension upgrades.
Today:
Mocking up a 1.25 gallon custom tank for the chiller. Have a lot of work to do, need to fix several leaks. One of which involves having to cut the aluminum fitting from the brick.
Will be using rivnuts in crash beam to mount tank. New insulation for tank on its way
Cheap diff brace
BMR cradle lockout
3.09
JLT intake
IC Chiller
Kirkey seat
Today:
