check engine light on, SRT pages erased after disconnecting battery.
Hemidayz
Las Vegas
NV
2020 WB Hellcat Charger
Any advice is appreciated. My battery died and had to pull the red tab to put her in neutral, so i can push her out the garage and down the driveway, jump it with my truck. After disconnecting the battery and reconnecting it and starting her up... the SRT pages are now gone, red accent is now blue accent. Rear camera is gone, check engine light is on and passenger side heat and cool are missing as well. I'm hoping I can come up with the solution before taking it to the mechanic.
Piening2150
Toledo
2017 Charger Daytona 392
Try to disconnect it again for a few minutes. After that, it may take a couple sleep/wake cycles for the Uconnect to regain all it's marbles & hopefully the check engine light will be erased. Had the same thing happen with my son's Charger when we replaced the battery.
The blue Chrysler accents/pages are the 'base' system and everything else has to load on top of it.
Slowpoke387
Everything will come back. That’s normal after a battery disconnect. Could take a day or so. Not sure about the CEL. I’d wait until everything else came back and then see what the CEL does.
As stated above, dead battery does bizzaro things, even illogical. The CPUs HATE low voltage!
Power cycles, including opening the door and closing twice, and on the second open, get out (off of the seat switch). (this from the Uconnect reset process).
Hemidayz
Hemidayz
Las Vegas
NV
car did reset to factory and CEL turned off. The rear camera comes on as well. Thank you
NYCSRTATE
NYC
Charger Hellcat
It should come back after a few key off cycles
