- Nanticoke
- PA
- 2016 Challenger He’ll Cat
Whipples latest Gen 6 3.8L Supercharger. Shipped 12/28/23 and Just arrived today. What comes with it make it a stage 2 kit. Included will Whipples 112 mm TB with a custom adapter that clocks it to clear the power steering pump on 15 and 16 hellcats or straight your choice it has a dual bolt pattern for the TB, Whipples fuel rail kit with fuel pressure sensor, the coolant hoses with insulation and abrasion resistant covering installed with 90 degree AN fittings on the coolant hoses and ported stepped AN fittings for in the supercharger lid (some scratches on the fittings from unfortunately removing the SC a couple times). The original MAP sensor wire extensions and a custom made plug and play no cut intercooler coolant temperature sensor extension harness so you don’t have to cut your OEM harness, a custom made super magnet oil drain plug for the Whipple, fresh from whipple install kit that is in the box with the supercharger which includes all new orings and intake gaskets, and Satera’s latest just received HD clutched pulley clutch assy and a 3.75 pulley shell and your choice of another in size you want as he owes me a pulley shell yet. The Satera clutch hub will come with the Satera made puller to pull the hub off the Whipple and install the Satera clutched hub on to it (1200 value). Also included will be a customized to fit the 3.8 Whipple AAD idler pulley assembly. Will include 316 Stainless Steel hex head cap screws that bolt the blower to the heads.
I’ve decided to go compound boost with a Hellion kit through either my ported 2.4 IHI or a 2.7 IHI that’s in the process of full porting including runners and port matching to my Thitek ported heads. For street play and roll racing this route will allow me to go back to a flex tune to run any fuels, gasoline for winter storage or when ever wanted, or a dedicated kill tune for max power all with just the turn of a dial.
7500 cash or PayPal
7500 cash or PayPal
- 1
