- Graham
- WA
- 2015 Challenger Hellcat
I am replacing the cam in a 392 Charger and deleting the MDS operation and doing an oil pump and timing chain (it has almost 80,000 miles and I am there anyway).
I am curious if anyone here has done a cam replacement in a new hemi. If you did what did you do for a cam break in? I am reading up on roller cams and its a little unclear if a new cam in an old motor (not a new or rebuilt motor - so the actual motor break in is not needed) requires special break in steps. In a flat tappet cam (cam replacement) the concern is around having the correct additives such as ZDDP (Zinc/Phosphorus) to prevent wiping a cam lobe during the breakin process. I have seen this happen on the flat tappet cams and a little prevention goes a long way. I am thinking I can add the additive (comp cams 159 additive) to the normal oil (0W-40?) during breakin, then change the oil and filter and I should be good? Does a broke in motor with a new roller cam need this much attention ? (or more?)
I know a lot of you have a lot more experience here than I do and I would like learn from what you found works best...
