Tuning for the first 60 feet.
AlleyCat
Oro Valley
16 HC Challenger
I thought I would share this with fellow members. According to a couple of professional tuners there are three ways to get off the line on a sketchy track. If you are getting traction there is no need to make a change to your tune. I will only share the easy way of doing this and indeed it is extremely easy.
Go to Engine
Go to Torque Management
Go to Torque Limit Per Gear vs. MPH
You will see for gear one vs. MPH a maxed-out value. Mine was 967.
Change that value to where you start hooking up at the track. This will take some time with TNT.
You may only put 300 up to 10 mph and then 500 after that till 45. That is something you will have to experiment with.
Good luck and glad to share!
