Too much boost
Points
Hamburg
Germany
hellcat
Who‘s running 2.65 upper an 9% lower on race fuel 100-102 oktan...
How much boost is it ???
Diabolo Tune with PCM and 1100 DW injectors available
We have pump gas ⛽️ with 100 oktan (Shell) and 102 (Aral) here in Germany
If no one, what’s the max upper I can go with 9%lower on 102 pump gas??
Phast Hemi
Points
SHELBY TOWNSHIP
Hello, does the 100 and 102 octane fuel you have access to contain lead?
K
Points
Hamburg
Germany
hellcat
no unlead
Phast Hemi
Points
SHELBY TOWNSHIP
That's a lot of boost for that fuel. I would start with a 3.10 upper and your lower and datalog for knock. You may be able to work your way up to a 2.85 but I would log it first with the bigger upper pulley.
cole3986
Points
82
Lawrenceville
Hellcat, Demon and project X
It is a canned tune meaning that it cannot be adjusted, correct? If so, I agree with Simon, data log and sneak up on it looking for knock in the logs.
K
Points
Hamburg
Germany
hellcat
no, it is fully adjustable... PCM is unlocked for diabolo and we tune it by hand
cole3986
Points
82
Lawrenceville
Well that changes things, you could run the combination pull timing and sneak up on with timing (add timing until you get knock). My gut is that it is not enough octane to run optimum.
oilburner
Points
coboconk
do you measure octane the same as we do ?.......... r+m divided by 2 = octane
K
Points
Hamburg
Germany
hellcat
whats r + m ?? our pumpgas is 100 octan by shell and 102 octan by Aral
oilburner
Points
coboconk
2 different methods for testing octane. R is short for research an M is for motor. different operating conditions for testing . so they take those numbers from each test method add the 2 together an divide by 2 to get the octane #. I think you will find your octane number is calculated different than in north America. so hard to compare our octane rating to yours unless we know the method your country uses.
oilburner
Points
coboconk
in other words our 93 could be equal to your 100 depending how they test for octane.
Points
The 110 here, Fl, is leaded.
Points
Stuttgart
2016 Challenger HellCat
Here in Europe(I'm in Stuttgart), the octane is calculated by RON and generally listed at the pump by the RON number...Shell V100 has a RON of 100 or US equivalent of 94 while Aral 102 has a RON of 102 or US equivalent of 95.
Thats the way I understand it....
parttimer
Points
7
crazyweathertown
Yes, the US octane rating is different than other countries.
Points
Braselton
If this is the case, that will be way too much pulley for the octane level. You will need a larger one to run safely.
Similar threads
