Tire sizes on a widebody hellcat, what's actually stock?
New York
Dodge
I've got a 2020 Charger Hellcat and I'm trying to sort out the tire situation. The door sticker says 275s up front and 305s in the back, but I've seen some widebody cars running different setups. Some have 285s, some have 315s, and I'm not sure if those are factory options or aftermarket choices. I don't have the original window sticker so I can't verify what this car actually came with. The Pirellis on it now look right but I'd rather confirm before I drop money on new rubber. Anyone know what the actual factory tire sizes are for a 2020 widebody Hellcat? Trying to get this right before I order anything.
I believe it's 305/35s all around for the widebodys OEM
More than a few options for tires....Pirellis are not the best all around choice...alot depends on weather...and how you drive...
New York
Charger
For the 2020 Charger Hellcat Widebody, the factory tire size is the same on all four corners: 305/35ZR20 on 20x11-inch wheels. The 275/305 front/rear combo you described is actually the standard setup for the non-widebody Charger. https://dodgewindowsticker.com/buildsheet-by-vin, for the original window sticker using your VIN, which will show the exact factory tire size and every other option it came with.
