SOLD. 7 Gallon EMP Ice Box
Trader history for Marc W (0)
This is the hot setup for keeping your Intake Air Temps under control at the track. This is out of my car because I had to switch to the side mount version to make room for a fuel cell in its place. It has the 40 gpm Davies Craig water pump (the one you want). This setup retails now from EMP for $649. I covered the sides and bottom with a couple layers of thermal barrier. That helps keep the cold cold in a hot trunk space. When using this setup, you bypass (or remove) your OEM intercooler pump. Don’t need it with this Davies Craig bad boy. The heater hose that is used to plumb this from the trunk and back is not included. It is extra from EMP and you can simply purchase that from ACE Hardware for less. I’ll take $400 ($250 discount from new). Shipping will be at cost. FBBD318B-A1CB-4A99-9D1E-2A4FE45234ED.jpeg 8B886371-D44D-4FEF-B605-36CEC14572F3.jpeg AC69A5B0-C9EA-4E9B-8F32-ACC7AC0628D9.jpeg 3155C14E-7064-4874-BC47-45B3D8B035E0.jpeg D208AA5E-76A9-42F2-A1E4-07220C9F4704.jpeg 31684C5B-C7C7-425A-8DA5-CC0EDA69B203.jpeg
