    Welcome to the #1 SRT Forum and SRT community dedicated to SRT owners and enthusiasts. Register for an account, it's free and it's easy, so don't hesitate to join the SRT Forum today!
Odd noise while car is shut off sitting in my garage
Jonnjohns
Waynesboro
Hello good people, I have a question about a really weird noise coming from my engine occasionally, after the car is shut off in my garage. It sounds like a high pitch squealing noise, somewhere in the area of the Supercharger but I cant quite pinpoint it. It makes the noise sorta quietly, for about 3-5 seconds, and then stops for approx 2-3 minutes, as then repeats. It happens when nothing is turned on or running, and as stated before, It sounds like it's coming from the SC area when I lean into the engine area and listen real close. I know that it's hard to troubleshoot a noise without hearing it but I am open for ideas and maybe someone has had this happen or heard of this issue. It's almost like a high pitch electronic squeal but real low in volume, and sorta like pressure releasing?. Please help, this is driving me crazy and if I take it to the dealer, it probably won't do it there. Thanks in advance.
Sent from my SM-N950U using Tapatalk
LonestarHellcat
Is it more of an electric noise or from the pulley?
J
Jonnjohns
Waynesboro
Is is definitely electronic, it happens when everything is off.
HellcatMike
Dont worry, that's normal. It's the airvents opening and closing.
HarleyHetz
ARLINGTON
What I Drive
2019 Sublime Widebody Challenger Hellcat
Which air vents, because it does it on my 392 as well...
Simi Valley
What I Drive
Are you talking about if you shut car off and say inside until cabin power shuts off? Mine sounds like a clunking sound as opposed to a squealing sound. Once you shut car off I open the door (to kill power) then shut door again...haven't heard that sound since I've done that procedure. Not sure what that sound is though?
HarleyHetz
ARLINGTON
What I Drive
I'm not, and I don't believe the OP was either. This is a whining sound that occurs after you shut the car off and get out. You can hear it outside the car. I have heard it while washing the vehicle. It sounds almost like air escaping from a small orifice...let the jokes start now...
Simi Valley
What I Drive
Why yes. The one time I washed my HC with the engine hot...I started to hear a beep/chirping sound (very similar to some low battery beep/chirping from some devices). I thought it was something in my garage, but it was from HC engine. Haven't washed HC hot since then and haven't heard sound again
45-70govt
albuquerque
What I Drive
As weird as it may be, I can hear a very high pitched sound from the headlights before they turn off.
HarleyHetz
ARLINGTON
What I Drive
Well, I wasn't washing the engine at the time, and it has happened several times, all with the hood closed...no biggie, it hasn't exploded yet...
HarleyHetz
ARLINGTON
What I Drive
Do you have LED headlights? It may be the fan on the back of the lights that you are hearing...otherwise, I've no clue!! :unsure:
Simi Valley
What I Drive
I leave early in the morning when the garage is dark...I love that sound when I open the door and everything comes to life. HC is getting ready for mayhem I guess? :devilish:
A day with that sound is a good day for me.
Confuzed1
Go Pack Go
What I Drive
2019 Hellcat Redeye Challenger Widebody
Could be coolant escaping from your radiator cap back to the coolant reservoir, which would be normal. Then as the engine cools down, the coolant gets sucked back into the radiator.....at least that might be the "air escaping" noise. The electronic noise?....don't know that one.
45-70govt
albuquerque
What I Drive
Nope, just the stock lights.
ELKHART
IN
What I Drive
2018 Challenger Hellcat Widebody
Did you have AC running?...sounds like you described are similar for the first couple of minutes as system equalizes.
Simi Valley
What I Drive
Ok, not joking. Got home after work and decided to wash my tires and a touch up wash. Did not get water in vents. Hour and a half later I go to put our trash cans out. Left car in sun and is 93+ degrees today...hear the pissssst sound. Not sure what it is but I never hear it when I get home and pop my hood up with fan on engine...which I normally do to keep garage from getting super hot. My bet is a heat dissapation thing...maybe A/C or coolant related as discussed above. Sure would like to know...curious now.
