How to cut a spring the right way ?
Indigo Joe
The sticks
NOT that I am going to do this other than to play around with ride height for a temporary project, what would be the best way to accomplish this ill-advised task ? I am assuming the easy way would be to use a sawzall except that I have no idea if the hardness of the spring will wipe the teeth off it in about 3 seconds. What about using a specific type of disc on a high speed air tool and keep ice packed around the coil to attempt to salvage the temper ?
Someone with experience has been there and done that and I would like to hear about it.
Thanks...
Indigo Joe
Indigo Joe
The sticks
Thank you for the link. Much appreciated.
ofdfiremedic
2016 Challenger SRT Hellcat
Cut off wheel 100%, however, the price of lowering springs are so cheap, for safety sake I would never advise it.
Blkout
Warner Robins
Cut off wheel is fine, I've done is several times, I would advise that you take it slow and let the spring cool though as you go along.
