Future Build
areuriding
Manassas Park
VA
2020 REWB
As some of you know I sold my Hellcat and will be purchasing a RE WB in the spring. I'll be building this up and have put together a fairly good list of my build. I'd like opinions of the future build as well as any suggestions of what I may need but have missed. My goal is a solid build that I can daily drive if I want and rip off some track days on weekends, again reliability is key. So if your interested and knowledgeable have a look and give me your thoughts.... Thanks as always, Ken
Price
Quantity
Total
HHP
In-House 2015+ Hellcat Tuning Package (PCM, Diablosport Trinity & Dyno Tuning)
Transmission
Automatic Challenger
Change
$2,000.00
Decrease Quantity:-Increase Quantity:+
$2,000.00X
HHP
HHP 180 Degree Thermostat & Gasket (ALL HEMI Engines) - 10183
$26.95
$26.95X
BWoody
BWoody Hellcat Heat Exchanger (2015-2019 Hellcat Vehicles) - 410.4007
Upgrade Options
No Upgrade
Options
No Thanks
Change
$499.99$399.99
$499.99$399.99X
Moroso
Moroso Coolant Expansion Tank (2015-2018 Hellcat Charger & Challenger) - 63812
$429.95$408.45
$429.95$408.45X
Moroso
Moroso Supercharger Tank (2015-2018 Hellcat Charger & Challenger) - 63809
$228.95$217.50
$228.95$217.50X
S&M Performance Driveshaft Loop for Automatics - (2015+ HEMI Cars HP70 / HP90 Transmissions) - SMPADSL
$200.00
$200.00X
Driveshaft Shop
Driveshaft Shop 1400HP Axles (2015+ 6.2L Hellcat and 6.4L 392 SRT-8 Cars) - RA7285X5
$1,679.98$1,545.58
$1,679.98$1,545.58X
ARP
ARP Bolt Kit Set of 5 Bolts (M10 x 1.50 x 65mm)(Upgrades for DSS Axles) - 672-1013
$20.09$18.08
$40.18$36.16X
Driveshaft Shop
Driveshaft Shop 1000HP 1-Piece Carbon Fiber Driveshaft (2015+ Challenger Hellcat & Demon Automatic) - CHSH36-C
$1,732.49$1,593.89
$1,732.49$1,593.89X
Mopar
Mopar OEM Dodge Demon Map Sensor - 53010887AA
$43.95$41.75
$43.95$41.75X
Comp Cams
HHP/BES Custom Limiter Street/Strip VVT Camshaft (2015-2019 6.2L SRT-8 Hellcat Dodge Challenger, Charger, Jeep Trackhawk) - HHPCAMHELLCATSS
Vehicle Model
Challenger
Phase Limiter Kit
Add Limiter Kit (Add $86.95)
Spring & Retainer Kit
Add SpringKit2 w/Shims for Demon/Redeye (Add $499.95)
Transmission
Auto
Change
$1,216.85$1,156.01
$1,216.85$1,156.01X
hhp racing
HHP/BES 6.2L (Hellcat Heads) CNC Ported Pro-Grade Cylinder Heads - HHP-62PPH
Head Core Charge
Install at HHP
Select Stage
Stage 2 (Add $499.00)
Change
$2,198.95$1,998.95
$2,198.95$1,998.95X
ARP
ARP Head Stud Kit (5.7L/6.1L/6.4L/6.2L HEMI Engines) - 244-4300
$423.76$381.38
$423.76$381.38X
Borla
Borla ATAK Catback Exhaust System w/AEV Simulators (2015+ 6.2L Dodge Challenger Hellcat) - 140648
$1,399.99$1,329.99
$1,399.99$1,329.99X
hhp racing
HHP Racing Dual Pump (Walbro HELLCAT 525LPH) Returnless Hellcat Fuel System (2015+ 6.2L Dodge Challenger & Charger) - HHP.HC.FUEL
88mm Filter Kit
Yes
Change
$1,650.00$1,450.00
$1,650.00$1,450.00X
Kenne Bell
Kenne Bell "Dual Boost-A-Pump" 21V Plug N Play (2018+ Demon, Redeye and Trackhawk) - KB89092P
$562.00
$562.00X
Injector Dynamics
Injector Dynamics 1340cc injector set - 1300.48.14.14.8
$1,800.00
$1,800.00X
Forced Inductions
Forced Induction Interchillers - Blower Spacer Plate and Thermal Blanket - Hellcat, Demon, Trackhawk and Redeye - FICHILL
$495.95$476.11
$495.95$476.11X
AAD
AAD Billet Drag Pack - (2006-2020 Dodge Charger/Challenger/Magnum Chrysler 300) - AADDP
$1,389.00$1,298.71
$1,389.00$1,298.71X
Jokerz Performance
Jokerz IHI Race Blower Package - IHIRACEPACKAGE
Core
None - I will supply my blower first
Coolant Brick Deep Clean & Pressure Test
No Thank You
FI Interchiller & Blanket
None
2018+ Runner Porting
Yes ($600)
Pulley Options
Hellraiser 2.85 ($649)
Jokerz Coating (Lower Blower & Snout)
None
Lid Coating Only
None
Change
$3,749.00
$3,749.00X
Mickey Thompson
Mickey Thompson ET Street S/S P305/35R20 Drag Radial 3402 - 90000024578
$404.40$392.27
$808.80$784.54X
HHP
HHP Racing Hellcat, Demon, Trackhawk & Hellephant - 105mm Throttle Body - HHP105HCTB
(Expected release date is 12/31/2020)
Options
Standard Length Bolts (No Plate)
Throttle Body
Sending my stock Throttle Body in for $75 Store Credit
Change
$899.95
$899.95X
  • Subtotal:
    $22,356.91
You don’t have a diff brace on your list. The DIRS front and rear would be a suggestion. For those weekend track days you’ll need a set of track wheels and tires. 20” wheels are going to be a handicap on the track. 17’s will be a minimum with the power you’ll be making. And (my personal experience and observation)... the Diablo Trinity is unreliable. I’m on my third and others I know have had issues with it as well.
A
areuriding
Manassas Park
VA
2020 REWB
Your right, Added the brace the wheels I'll probably do later. As far as Diablo I'm glad you mentioned it as I have zero experience with Diablo. My last HC was tuned with HPT. It seems HHP doesn't use HP Tuners. That's something I'll need to research as the time gets closer. Thanks for your input..
Did you ever race your old Hellcat?
A
areuriding
Manassas Park
VA
2020 REWB
A couple of times mostly sneaky on the street. This time I wanna go to the track and get some actual times. The couple times I ran before were just against others with NT mainly cuz I didn't wanna see how bad I would do...LOL
A
areuriding
Manassas Park
VA
2020 REWB
Silver Billet, I see it says you sold the Charger??? Did you get something else??
No. Sold my Daytona too ( my new golf cart cost more than I got for my Daytona:oops:). Just part of our downsizing before we move permanently to our other home in Florida next Fall. Keeping my Barracuda for now but not real attached to it either. I’d really like to get a Charger Redeye but the Barracuda would have to go. I have options. I’m just going to have room for one toy, a daily driver and two golf carts. Once we move, the 2001 CTD and 24’ trailer will also be sold.
A
areuriding
Manassas Park
VA
2020 REWB
Wow, Big changes coming your way, Congratulations.... I assume your retiring??
Retired a few years ago and built a new house in Florida. It will be less cars and coffee and more golf! I still really enjoy associating with these awesome machines vicariously through all the guys on this Forum! Hope you get to build your car but can’t help but think a stock REWB in the color combo you want would not need any improvements?
A
areuriding
Manassas Park
VA
2020 REWB
Yeah well, I just can't leave anything alone.. Been that way my whole life.... It's a weird quirk I have. It was exasperated when I retired after 30 years in the ARMY and found myself trying to figure things out if you get what I mean. So, it keeps me busy and keeps my mind from getting dulled.
DMNkilr
Doctor
7 Second Best E/T
Highlands Ranch
2016 Hellcat
Nice parts list, If I was going to update the heads, I'd consider going all the way to a set of Thiteks. I agree with Marc on the wheels/tires. The 17" Mts are really good, if you don't want to go the 15" rear wheel conversion. Much better than the 20" or 18" options.
A
areuriding
Manassas Park
VA
2020 REWB
I really thought about the heads, cost kept me away. I figured I'd go this route and if something happens then I'd be forced into Thiteks, and I'd be ok with that.
What fuel are you running? I see the 2.85 upper, but no lower. You have a nice fuel system picked out... so I would imaging you're going to run E85, and if so, I'd either pulley down more on the snout or add a 10% lower to make some real power (or both).
A
areuriding
Manassas Park
VA
2020 REWB
Yep, I forgot the 10% lower.. It's been added to my cart now.. Thanks! E85 isn't readily available around here as of yet. For fuel I'll have it tuned for 93 and EVO10 I think but not for sure yet.
Dman007
6 Second Best E/T
Smyrna
2019 Charger Hellcat
Agree with Marc about the power and trying to put it to the ground.
The rear diff brace is $200 and will save you from wheel hop and snapping your driveshaft or diff, thus saving thousands of dollars in repair bills.
As far as tires, agree with @DMNkilr. Go with 15" conversion, add beadlock wheels and 315 tires and MT ET Pro 315/60/15 will hook up and give you the best results. In my opinion, any less of a tire will be a spin feast and you will not see the ET per the money you spent on power.
One last thing, spinning a ported blower with a 2.65 upper & 10% lower is causing a lot of heat and I would only run a 2.75 with 10%. Talk to Josh (HHP) if this is a good idea on the 2.65/10%.
A
areuriding
Manassas Park
VA
2020 REWB
Dman007, I think you missed it... I already added the brace to the list and I'm not running a 2.65 upper, I'll run a 2.85. Thanks for the input, as far as wheels I may end up with a street set and strip set. I'll have to see how that pans out as I don't have gobs of money and I'm already over my original budget lol...
A
areuriding
Manassas Park
VA
2020 REWB
I've updated my list...
Item
Price
Quantity
Total
HHP
Transmission
Change
$2,000.00
$2,000.00X
HHP
$26.95
$26.95X
BWoody
Upgrade Options
No Upgrade
Options
No Thanks
Change
$499.99
$499.99X
Moroso
$429.95
$429.95X
Moroso
$228.95
$228.95X
$200.00
$200.00X
Driveshaft Shop
$1,679.98
$1,679.98X
ARP
$20.09
$40.18X
Driveshaft Shop
$1,732.49
$1,732.49X
Mopar
$43.95
$43.95X
Comp Cams
Vehicle Model
Challenger
Phase Limiter Kit
Transmission
Auto
Change
$1,216.85
$1,216.85X
hhp racing
Head Core Charge
Install at HHP
Select Stage
Change
$2,198.95
$2,198.95X
ARP
$423.76
$423.76X
Borla
$1,399.99
$1,399.99X
hhp racing
88mm Filter Kit
Yes
Change
$1,650.00
$1,650.00X
Kenne Bell
$562.00
$562.00X
Injector Dynamics
$1,800.00
$1,800.00X
Forced Inductions
$495.95
$495.95X
AAD
$1,389.00
$1,389.00X
Jokerz Performance
Core
No Thank You
None
Yes ($600)
Pulley Options
None
Lid Coating Only
None
Change
$3,749.00
$3,749.00X
Mickey Thompson
$404.40
$808.80X
HHP
Options
Throttle Body
Change
$899.95
$899.95X
Per4mance
Per4mance Development Differential Integration and Reinforcement System (2015-newer V8 Chargers/Challengers/300 RWD)- P4D-DIRS
DIRS Option
Borla (Non-Typical Routing) ($30)
Change
$549.00
$549.00X
HHP
HHP Crank Pinning Kit (2015+ Dodge 6.2L Hellcat Challenger, Charger SRT8) - HHP62PINKIT
No. of Pins
2 (Add $7.50)
Change
$106.45
$106.45X
ATI
ATI Super Damper Harmonic Balancer, 10% Overdrive (2015+ Supercharged 6.2L HEMI HELLCAT Charger & Challenger, Demon & Jeep Trackhawk) - 918485
Options
No
Crankshaft Options
Decline Required Crank Bolt
HHP Add-Ons
Add Gates K100594HD Belt (Add $49.95)
Change
$547.90
$547.90X
  • Subtotal:
    $24,680.04
  • Grand total:
    $24,680.04
Primetime Hellcat 17
Phoenix
2017 challenger Hellcat
Get rid of the KB boost a pump. Some have been known to fail and Ka Boom!
You mine as well just upgrade to a triple pump system for room to grow in the future. Don’t skimp out on your fuel system.
mine as well get the 1700cc injections as well.
You are looking at $2200 for the dual pump with BAP fuel system. The pumps are good. The BAP’s have been proven to be less than 100% reliable. Plus... I don’t like juicing the pumps to “make them work harder”. It works but.... Suggestion...... We have two cars in the shop (one of them mine) that are removing Fore 525 triple pump systems that are full return and rated for 1700 hp without boosting voltage. Full steel braided fuel lines (both supply and return), adjustable pressure regulator, inline billet filter, etc. Both are in like new condition. I will sell mine for $2500 complete (minus fuel rails). I would also suggest going with 1700 injectors. A few extra dollars but they buy you some breathing room.
Dman007
6 Second Best E/T
Smyrna
I would get away from using the 525 and go to the improved flow 535 pumps.
