Front end popping noise after lowering
rdlsrt
Pearland
Sounds like it coming from front drivers side. Popping with turning, like something binding. Looked and the front rubber seat isnt aligned like it should be with spring, but I dont think that can be the exact cause?
Wont get a chance to take it off and realign it till next week. Any other ideas I can check while I am tearing it down? They are Mopar springs by the way.
Thanks.
I'm on stock springs but when I did my front end links , I didn't get them tight enough at first & had a little popping noise up front when turning the wheel. I retorqued to 80 lbs. ( what was recommended ) & it's been fine ever since.
rdlsrt
rdlsrt
Pearland
Which links exactly are you talking about? Top ball joint, joint connected to strut and shock connected to bottom end? What about the 3 bolts up top?
Sorry , I'm talking about front sway bar end links. sway bar to end link to shock.
rdlsrt
rdlsrt
Pearland
I will try it out.
rdlsrt
rdlsrt
Pearland
Took the tire off, turns out the bottom screw that connects the shock to the lower arm was not tight. Tightened it to 80lbs, no more noise. [clap]
Glad you figured it out. :cool:
