Dyno
Boston
MA
2015 Hellcat Challenger
Dyno My Car two months Ago. Going to add a chiller ice tank and dyno again in the Fall with a 3.75 or a 4" upper. Made 1009 rwhp on a 90 degree day. Temps were 101 inside the shop.
Mods Were 4.5 Whipple 4.5" upper & 10% lower ATI. E85. Whipple Billet Big Bore Throttle Body. ARH Long Tubes. Upgraded large Aluminum front Heat exchanger. Barth triple fuel pump. Injector dynamics ID1300x, RSG Tranzilla, Mantic Triple Disc
Nice numbers have you ran it at the track?
My experience with the 4.5 Whipple…. One of the single most effective things you can do with that supercharger is plenum spacers. I made 1200 rwhp five years ago with that 4.5. Car ran 8.7 at 4500 lbs with that combo. I was running a +10 at the crank with a 4.0 Griptec. One of the issues that supercharger has is belt control and it needs one of the high tension aftermarket belt tensioners to do that at the higher boost levels. I would also recommend not going smaller than the 4.0 on the supercharger. A icebox/chiller to reduce your IAT will also be a huge benefit when the boost goes up. That is not a cool running supercharger compared to the new gen Whipples. Also…. I would increase your injector with those changes. 1700’s at least.
I
Boston
MA
Before I did a Dyno tune I ran a 9.4" my PB. That was with my car weighing around 4400 with stock suspension on a 17" Radial. I'm going to wait until fall when I add my chiller tank, 15" rear conversion. AAD suspension Drag pack, Demon Springs some 15" weld beadlocks and slicks. I been saving up all summer for the parts. And Gut the car some more to lose weight. My plan is to crack a 8.9. without adding anymore power because I'm SBE. Plan on relying on weight and suspension now lol
I
Boston
MA
Damn 8s that's very impressive. Where I'm trying to be. My tuner suggested the same thing. Told me not to drop down below a 4" unless I decided to get a 426 with my 4.5" whipple. And also suggested to get the icebox chiller for when we retune in the fall. Decided not to go too aggressive on the dyno due to it being so hot that day and heartsoak. My plan is to Gut my car to as close to 300 pounds Off. Invest in a full drag suspension / 15" rear conversion & shoot for a 8.9 pass. I feel it would be very possible with an automatic but being it's a stick I know it will be a Feat
Good plan 👍🏼
Buda
2016 4.5 Whipple Challanger
I have a 4.5 Whipple Car With a Old Killer Chiller and Built Billet Rod 376 , Looking For Some More Cooling , With FI spacers did you need to Source Custom Hardware Currently on a 4.0 / Stock Size Lower Spinning 7000+ ( i do roll race events + in mexico )
2022 Challenger Super Stock
Mexico:ROFLMAO::LOL::ROFLMAO::LOL::ROFLMAO::LOL:;)
Get an IC chille. How cool do you get your IC temps? I can get down to 24 on the ic coolant temps with an IC chiller
Buda
the
They Fluctuate i Usually See 60-65 IC & 80-90 IAT’s on a 70+ degree day , but for some reason when it’s below 60 outside IC Temps are at 80-90 & Iat’s are between 90-110 , seems to run hotter even when it’s freezing outside.
with the drag valve on?
Buda
this is jus standard temps , drag mode is lower , but cuts ac to cabin any time i put AC above “ Low “ Temps climb by another 10 Degrees , when riding around when it’s 50 outside with AC on gets old. seems like it’s just a dated system , 110+ iat when it’s 50 degrees outside but yet it can be 80 and iat’s will be in 80’s , think spacer plates will help isolate blower but asking op hardware he used
