Add a fuse in under hood fuse box
I need to tap into a fuse that’s hot when the key is on. I’m thinking about tapping into 39, which is the AC compressor. I’ll be adding a 5amp fuse in addition to the 10 amp that’s already there. Any issues with this? The electronic I’m hooking up “should” only pull 5 amps. Any other suggestions?
Thread Starter #2
Bump, anyone?
Helloooo
Seems like that be ok but idk, does it do anything else beside cycle the ac clutch? How about the wiper motor?
