2015 Hellcat brake pad shifting
Finally identified the metallic knock in the left front right side of the Hellcat. Apparently the brake pad is shifting forward and aft in the caliper. Anyone seen this one before. Also any idea on a fix?
Not an expert on this Greg;
pad is ok as is?
Pins in calipers ok?
pad is ok as is?
Yep everything is good. I’ve been using Power stop pads on both cars since I got the Hellcat in 2015. First time for this problem.
Don't these have backing plates held in place by little metal 'tabs' that bend around the pad frame? If so, could be broken or loose tab(s) on that pad ?
Yes they do and they look good.
Thx
the pins and the metal retaining spring plate on top look good? That will be your issue - the spring plate and pins are worn. If you can move the pads by hand with the wheel off the spring plate on top of them isn't applying enough pressure
Thanks. Gonna try that later today. Any idea where I can get the pins and springs?
Got dog dying this morning. Waiting on the vet to put her down. She had 15 good years.😢
I'm so sorry to hear that, heart breaking. I know how it is all too well, you gave them a good life...
possibly advance auto but you'll have to shop around
Thanks. She has had a good life and made me happy even when I didn’t want to be.
Duralast makes it too, might be available on Amazon
Duralast ones are from autozone
23 Challenger Demon 170
Sent you a dm
Above were for the rear, these are for the front
Did you use the PS items when you installed them? Did you keep the OEM if so? Or vice versa? I do have a couple sets of the retainers and pins laying around. Let me know if I can help you out. Cheap to send you a small package. It has to be something that easy.
I think I reused the OEM stuff.
Well I did finally read the balance of the thread. If you can find the PS hardware try it. I see you can order a set. Or you can tell me to go to the shed and find a set to send to ya.:love:
Got a set on the way from @jgilg.
Are the retainers easy to come in and off?
Pets have the ability to do that...(y);)
