Gates green stripe blower belt
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
During research on Gates belts for our blowers I happened across a listing for gates green stripe belts. Has anyone heard of these? Are they any better than the green gates belts #100579 at Amazon for under $40?
Thinking they are the same belt. I run the standard black belts. The green belts can snap being they have less give and they don't grip any better
I use these belts, they are made for supercharger use, they hold up well and I turn my superchargers pretty hard, used same one on my whipples as well when I was running them.
Octanewide
House of power
Are @16GoManGoHC2 for stock blower pulley diameters?
That size belt fits with using the AAD Idler pulley in center mounting hole with +10 lower with that 2.74 Satera Griptech prepped upper with 1/2” thick FI Insulator Spacers. Blower making 25.5 psi of boost very little belt dust.
Also fits +10 lower stock upper and no spacers or idler pulley.
Yes, 25.38 to be exact with my hand ported 2.7 snout and 105 TB, has my custom billet 2.7 inlet plate with oiled bearing, the thing is singing but staying happy so far!! Have to try the SDG snout and NW 108 TB someday.
Man that’s moving air! Wonder what mine makes no (just a dinky 2.4) pretty sure I’m maxing out the stock map sensors
Yes, seeing almost 2300 Aircharge and 2.82 PR
What pulley combo on you 2.4?
Nice!!
My guesstimate of boost on stock displacement, stock or RE cam, stock exhaust including cats, 20-21 psi 1900-1950 aircharge.
Yes, most likely your 2 Bar map sensors are maxed out around 18-19 or less. (2 bar is 14.7x=29.4 - 14.7 = 14.7 psi, that’s why RE 2.7 blowers where equipped with three bar sensors which read to about 30 psi of boost or so.
Nice!!
I do have long tubes though, 2” primaries
Probably still out of the sensors ranges.
I suggest replace your map sensors, all four of them with the 3 bar units and have them remapped in your tune, it’s just changing numbers. I may have a set around I could sell you for $200 for the four of them +$10 shipping. Let me know if you want them and I’ll look for them.
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
So will that belt fit with a stock idler and 3.10 upper pulley?
No idea with any certainty. How I get close for a belt size as I put a string around all the pulleys and then put the tensioner in about the middle of it travel and match the string up, put a mark on it and then measure its length and see what belts are available in that size
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
The correct number for the Dayco belt same size as stock is Dayco Racing 5100580S. I ordered it from Summit. I think it was $46
The 100 at front of number means it is a 10 rib. 579-580 would be a stock belt. Find a belt between 575-578 for a 3.10 pulley but I also wouldn't even bother with a 3.10 pulley. If you are changing the pulley you should go smaller because once you change it, you will again.
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
Just get an adjustable idler
My new Blackbird adjustable tensioner arrived yesterday. I should be OK now thanks. All my parts are here now and I am just waiting for the next opening at my local hot rod shop to get everything installed with Jon Moore's stage 2 tune. I'm not missing anything with this terrible weather in the Detroit metro area anyway. And Milan Dragway is not open yet from doing their complete rebuild. Its going to be a beautiful facility when its done in a few weeks.
Even though there are many holes in the tensioner bracket, one spot moves it a lot. Based on what pulleys you are running probably could tell you what size belt you need
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
I will be running the stock lower and 3.10 grip tec upper. I'm hoping my standard belt will fit.
Orem
<minor thread hijack, but belt-related>
Did you install the Blackbird tensioner yet?
If not, before you do, after you pull the stock one, set them both side-by-side on a flat surface with their locating pins hanging off the edge--then rotate them until their pulleys touch, with their backs still nice and flat on the surface. Now look at them straight-on edge-wise and tell me if the grooves on your Blackbird line up with the grooves on your stock pulley.
I have one sitting here and it's off by about 25-33% of the groove width. Clear as day the grooves do not line up. I don't dare mount it and run it--I think that would be asking for major belt dust and wear. Additionally, the Blackbird pulley has 6303 bearings with full contact seals--bigger bearings == /slower/--these are only rated to 11k RPM, and with full contact seals are going to get /really/ hot. I bet they don't last 5k miles. I have a TBA pulley here that had 6203 (smaller) bearings rated to 12k with less than 5k miles on them and they are just cooked.
Contrast to the Litens tensioner I have--the grooves line up perfectly with the stock--so I'm leaning towards thinking that the one out of alignment is the Blackbird unit.
Detroitboy
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
I'm glad you posted that because I am going to my installer Tuesday. I hope mine do not line up so I can send it back.
