- San Marcos
- CA
- 2019 Charger Hellcat
Looking for suggestions:
Background: New Charger Hellcat, less than a thousand miles, purchased new from dealer a month ago, don't know build date or how long it sat on dealers lot (need to look into that but I doubt it was for long - high volume dealer).
The car has been perfect so far except I have had several incidents now of a slow start. Each occurrence has been when the car is started after it had been previously driven for awhile shut down and sat for 10-20 minutes. By slow start I mean slow engine rotation with the starter motor. It has successfully started all but once. The one occurrence in which it did not start, I pressed and released the starter button, the engine turned over slowly and almost caught but died. I pressed the start button again and it successfully started and ran.
After sitting for longer periods of time there is no issue, starter turns engine at a good speed and light off is achieved, so car starts up with normal gusto.
My first thought is battery isn't healthy but the car starts fine most of the time even after sitting for days. (I have not yet checked resting voltage)
On that thought, I can see how batteries take a beating in transport from manufacturing to dealer lots and on the lots themselves. Quite possible its been taken too far down more than once. However, starts fine after sitting for a few days...
Second thought is that is seems like a heat issue. Maybe a poor connection somewhere that is worse when the car is heat soaked?
I swear I have read that others had this issue as well but my search here didn't bring up anything.
Anyone experienced this and if so was a solution found?
I'm not considering this a real issue yet but it could become one and just doesn't seem quite right. I'd much prefer an easy fix I can do than take it to the dealer.
