- memphis
- TN
- 2016 challenger hellcat
IM IN THE PROCESS OF TAKING THE TRANS OUT OF MY HELLCAT BECAUSE I HAVE CLUTCHES SLIPPING UNDER WOT
IF I GET ENOUGH RESPONSES ILL DO SOME VIDEO (WILL NOT BE SPEEDY QUALITY LOL) KEEP IN MIND ILL ONLY BE REPLACING THE STEEL AND FRICTION MODULES,FLUID AND FILTER IN MINE BECAUSE IT ONLY HAS 19,000 MILES ON IT AND NORMAL DRIVING THE SHIFTING IS STILL FINE. I KNOW THAT THE SEALS ARE FINE JUST HAVENT SEEN MUCH ON THIS ON THE FORUM ,BUT THERE IS MORE IN DEPTH INFO TO BE FOUND ON YOUTUBE IF YOUR CURIOUS ABOUT WHAT A FULL REBUILD LOOKS LIKE .ILL BE USING THE ALTO FICTION AND STEEL MODULE ,WHICH I BELIEVE IS ALSO USED BY SOUTHERN HOT ROD ON THERE UNITS
